Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Seeking Advice about Two-Phase "Ramping"
Old   May 6, 2023, 19:25
Default Seeking Advice about Two-Phase "Ramping"
Marshall McCray
marshallmccray is on a distinguished road
Hi all,
I'd like to open up a discussion about best practices, tips, and advice for reaching a converged steady-state solution for multiphase flows.
I will state my problem, but I hope the responses are helpful to a wide range of multiphase applications.
I am attempting to simulate bubbly, two-phase flow through a cylindrical annulus. The clearance between the walls is quite small: 0.2 mm and the inner cylinder is rotating at 3000 rpm. The liquid is benzene with the compressible liquid equation of state, and viscosity increased to roughly 10x that of water. The pressure drop from the inlet to outlet is about 35 bar, and the inlet gas volume fraction ranges from 0 to 0.1.
I have had success with pure liquid convergence, but can only converge the two phase simulation if the viscosity model is set to laminar. Turning on turbulence usually causes divergence.
Assuming my grid is okay (it might not be) I wanted to ask what order I should "turn things on" or ramp them up:
- slip velocity
- turbulence
- increase order
- per-phase turbulence
- compressibility of gas
- inlet gas volume fraction
For now, we could assume mixture model (as opposed to full eulerian) to simplify the post, but all answers welcomed!
Thank you,
Marshall
marshallmccray is offline   Reply With Quote
Complete noob to CFD, seeking advice. VelonautG CFD Freelancers 5 January 30, 2019 11:39
twoPhaseEulerFoam: dispersed phase not conservative? RL-S OpenFOAM Running, Solving & CFD 6 May 8, 2018 09:46
FVUS (Finite Volume Utilities and Solvers) / Wildkatze (solver) Updates arjun Main CFD Forum 30 July 22, 2017 04:27
Sharing links for two phase solver packages developed by openfoam community swap_9068 OpenFOAM Programming & Development 1 April 2, 2017 06:43
Two phase flow problem. andyraq Fluent Multiphase 4 August 21, 2016 22:57
