Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
How to patch species mass fraction in fluent for a converged solution?
Old   March 30, 2023, 07:51
Default How to patch species mass fraction in fluent for a converged solution?
Vidya Muthulakshmi M
Vidzz22 is on a distinguished road
I have completed a multiphase simulation (VOF) - Free surface type and obtained converged solution. The two phases are air and water. Now I am introducing three species in water phase within the same case setup. After defining the materials, I patched the mass fraction of species 1, 2 and 3 in all zones. I expected that the profile of mass fraction of the species to be same as that of the volume fraction of water in all grids of the mesh. But I am not getting the same profile. I request you to kindly help me out on finding the possible reason for the same.
Vidzz22 is offline   Reply With Quote
Old   April 12, 2023, 15:45
Andrew
andrew-c is on a distinguished road
Can you attach some images of the species mass fraction profiles and the water volume fraction profile in the flow?
If the species mass fraction profiles extend outside of the water volume fraction profile, try instead to view the profile of the species mass fraction (mixture level).
If the species mass fraction profile inside of the water profile is not what you expect, it may be an issue of diffusion within the water phase. You can check your diffusivity values for accuracy. Also note that, depending on the characteristics of your model, the species mass fractions may not exactly mimic the profile of water in every physical case.
If you attach some images, I may be able to offer some more suggestions
andrew-c is offline   Reply With Quote
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 06:37
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) Aadhavan OpenFOAM Meshing & Mesh Conversion 2 March 8, 2018 02:47
Define mass flow profile with regards to species mass fraction danS Fluent UDF and Scheme Programming 0 June 20, 2017 07:21
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
