Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Fluctuating Surface Under Constant Acceleration
Old   February 1, 2023, 10:04
Default Fluctuating Surface Under Constant Acceleration
Behrouz
BehrouzMohammadian is on a distinguished road
I am modeling sloshing of a fluid inside a container. For this, I am using VOF model. I consider two accelerations. ax=2 m/s2 and az=9.81 m/s2. The modeling continues for 2 sec. Physically, a container with a liquid inside under constant acceleration will have a steady inclined surface. However, the surface that I get fluctuates. As it is shown in the image the flat surface reaches to max inclination until t=0.8 sec. After that the surface starts returning to its original flat horizontal condition and again starting going up. Could you please let me know what is the problem?
Thank you,
BehrouzMohammadian is offline   Reply With Quote
Old   February 9, 2023, 10:45
Default Answer
Behrouz
After discussing this with others, I found my answer. So I mention it here because it might be helpful.
After applying constant acceleration to the container, the fluid starts gaining inertial forces and moves toward a wall. After reaching the wall it hits the wall and bounces back. That is the reason I get fluctuations. However, by continuing my model until t=10-15 sec, the flat surface will be almost steady at an inclined shape. So it is a matter of time to reach that steady inclined surface.
[snappyHexMesh] Problem with Sanpper, surface still Rough Zephiro88 OpenFOAM Meshing & Mesh Conversion 7 November 5, 2014 13:05
Calculating forces on a non-closed surface ScottN FLUENT 0 March 1, 2011 18:18
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 19:44
constant surface heat flux Andrew Hayes Main CFD Forum 4 March 16, 2006 08:19
Normal - Helical Surface m. malik Main CFD Forum 3 February 3, 2006 13:56
