Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Can I change pressure reference point after simulation has ended?
Old   December 19, 2022, 20:15
Default Can I change pressure reference point after simulation has ended?
Dryaspis is on a distinguished road
I just run a simulation that took 5 days to complete and realized that my pressure plot for a specific point is off to the negative values by about 100000 Pa. I didn't use the right point as a pressure reference.
Is there a way to offset the reference pressure at the result panel in order to correct my results without having to re-run the entire simulation?
Dryaspis is offline   Reply With Quote
ansys fluent, multiphase, reference -values
[General] Extracting ParaView Data into Python Arrays Jeffzda ParaView 30 November 6, 2023 22:00
Compression stoke is giving higher pressure than calculated nickjuana CFX 62 May 19, 2015 14:32
reference pressure and compressible flow bingo10 CFX 0 September 11, 2013 08:32
[blockMesh] error EOF in blockMesh Ahmed Khattab OpenFOAM Meshing & Mesh Conversion 7 May 17, 2012 01:37
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 03:27
