Multiphase VOF Open Channel Flow: Air Phase Streamline Question |
December 15, 2022, 21:48 |
Jake Bilsborough
Hi all,
I am attempting to perform a ship hull resistance analysis using open channel multiphase flow. My project supervisor believes that the streamlines in the air region are incorrect, and as such believes the whole simulation is incorrect. I have attached images of the streamlines, as well as the volume fraction and isosurface images extracted from CFD-Post. I am using pressure inlet and outlet boundary conditions with a set free surface level, with an inlet velocity specified at 1m/s (gravity enabled). I am not generating any waves. For this simulation I patched the volume fraction of water into its specific region, and have tested the simulation again using open channel initialisation protocols with the same effects. I am using the default k-omega turbulence model. This is a steady state simulation, but I am not opposed to trying a transient simulation. I am just looking for verification into whether the movement of air is abnormal, as my supervisor believes, or if this is typical VOF open channel air flow. issue.jpg main keel closeup.jpg main keel vel.jpg veloicty streamline.jpg water.jpg Thanks, Jake. Last edited by JakeB; December 15, 2022 at 22:05. Reason: Added that it is a steady state simulation |
[swak4Foam] swak4foam for OpenFOAM 4.0 | mnikku | OpenFOAM Community Contributions | 80 | May 17, 2022 09:06 |
Multiphase VOF - Flow in a Channel | harsha28 | Fluent Multiphase | 1 | July 8, 2020 17:39 |
modeling entering two phase flow in open channel flow | hesamabtahi | FLUENT | 0 | May 2, 2018 11:13 |
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' | mfiandor | OpenFOAM Installation | 2 | January 25, 2010 10:50 |
VOF modelling Open Channel flow | Rodi | FLUENT | 2 | August 11, 2007 14:15 |
