Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
ANSYS Fluent solutions abnormal exit after 1047 timesteps
Old   November 10, 2022, 04:12
Default ANSYS Fluent solutions abnormal exit after 1047 timesteps
Dryaspis is on a distinguished road
I'm doing a simulation of an OWC.
(2d, double precision, pressure-based, VOF, SST k-omega, transient)
58556 nodes
60483 elements
80.000 timesteps of 0.001s
Using AMD rysen 9 and 64 GB ram. At first I used all 16 cores then I used only 6 (~10k elements per core) same problem keeps appearing. Solving window simply shuts down, computer doesn't show any signs of lagging. It's like a command is being given. I 'am obviously using a cracked version of the program which was set up I believe using floating license from "localhost" (don't take my word on this last sentence, not sure what I was doing just following instructions for the setup).
Right before exiting, the solution writes :
"MPI Application rank 0 exited before MPI_Finalize() with status -1"
and an error folder appears in results with this message (time and date changes of course):
"Error [node 0] [time #/#/# #:#:#] Abnormal Exit!"
Besides the licensing I've seen this might be a problem related to automatic windows update or windows defender.
I am able to continue the solution every time from last save (I save every 50 timesteps) until it stops the same way after 1047 timesteps. I could keep doing this, however I keep losing some data from my diagrams and at this rate I won't reach the deadline for my University thesis.
Thank you in advance
Here's the first and last steps from the solution
sample of trancribe.txt
As well as the report
report.txt
Dryaspis is offline   Reply With Quote
#ansysfluent, #crash, #error, #license
Abnormal exit of Fluent mz_uon FLUENT 0 June 21, 2022 05:51
Parallel Error Abnormal Exit! Morice FLUENT 5 June 20, 2022 06:56
HELP - Exhaust exit boundary condition. (ANSYS Fluent) danquahj FLUENT 2 April 23, 2020 12:05
Abnormal exit of fluent shivakumar FLUENT 5 August 2, 2019 17:46
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
