Creating cell zone in fluent with separating mesh cells |
August 31, 2022, 09:06 |
Jam
Rep Power: 5 |
Hello all,
I am creating a small cell zone in my bioreactor after my flow field reached to steady state in a mixing tank (turbulent multiphase system). The cell zone is used for feed addition to the system through a mass source term instead of making a modification to geometry and adding a feed inlet (nozzle). then mass transfer and reaction equations are solved. -Do I need to define momentum source term when I have a constant mass source term? For some reason, I don't get consistent results between different geometries (same bioreactor at different filling, or different volume). all the settings are the same but the values I get for the amount of feed entering the tank is different (with the same feed rate). Does anyone have an idea why this might happen? Could it be because of separating cells in fluent instead of when I create mesh or geometery? |
feed, mass source term, mixing tank, multiphase |
chtMultiRegionFoam speed up | qwertz | OpenFOAM Running, Solving & CFD | 8 | September 18, 2021 06:16 |
SimpleFoam & Theater | jipai | OpenFOAM Running, Solving & CFD | 3 | June 18, 2019 10:11 |
Journal file error | magicalmarshmallow | FLUENT | 3 | April 4, 2014 12:25 |
[ICEM] Export ICEM mesh to Gambit / Fluent | romekr | ANSYS Meshing & Geometry | 1 | November 26, 2011 12:11 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
