August 30, 2022, 19:53 |
DPM for centrifugal fan fluent capability
amour aissa
Rep Power: 4 |
hello,
I am running a simulation of a centrifugal fan for erosion prediction, I calculated the flow field using the sliding mesh method. when I use the discrete phase model (DPM) to trach particles in the domain, particles are tracked only in the absolute reference frame.in fluent manual, I found the following: -When MRF are used in conjunction with the discrete phase model, the display of particle tracks will not, by default, be meaningful. Similarly, oupled discrete-phase calculations are not meaningful.An alternative approach for particle tracking and coupled discrete-phase calculations with multiple reference frames is to track particles based on absolute velocity instead of relative velocity. To make this change, use the define/models/dpm/ options/track-in-absolute-frame text command. Note that the results may strongly depend on the location of walls inside the multiple reference frame -Relative particle tracking cannot be used in combination with sliding and moving deforming meshes. If sliding and/or deforming meshes are used with the DPM model, the particles will always be tracked in the absolute frame. Switching to the relative frame is not permitted. the problem when I track particles they stop in the impeller suction side because the track is in the absolute frame of reference. please I need your help. |
dpm, erosion, fan |
Rotating blades of a fan by Fluent? | guillaume1990 | FLUENT | 17 | June 22, 2016 03:01 |
Rotating blades of a fan Fluent? | guillaume1990 | ANSYS | 1 | March 21, 2014 03:15 |
Conditional Release of DPM Particles in Fluent - UDF | nvschandra | Fluent UDF and Scheme Programming | 0 | December 16, 2013 20:32 |
Problem in using parallel process in fluent 14 | Tleja | FLUENT | 3 | September 13, 2013 10:54 |
problem in using parallel process in fluent 14 | aydinkabir88 | FLUENT | 1 | July 10, 2013 02:00 |
