August 8, 2022, 17:27 |
mixing of fluid at mating wall
vikash
Rep Power: 6 |
Greetings!
I am working on the interdigitated flow channel, where mating surfaces (internal) are supposed to diffuse the liquids from one side to the other. I experimented with different boundary conditions: internal as internal, which led to merging the surfaces and making a single entity. Additionally, I made internal as wall, which prevented the liquids to cross and do diffusion is observed . I am intended to observe diffusion at mating surfaces. Could you please suggest a suitable boundary condition? |
temperature correction limited- Star ccm+ | LpSingh | STAR-CCM+ | 15 | September 29, 2020 11:06 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 11:19 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
[ICEM] Export ICEM mesh to Gambit / Fluent | romekr | ANSYS Meshing & Geometry | 1 | November 26, 2011 12:11 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
