Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Initialization of DPM particles for transient simulation
Old   July 6, 2022, 04:34
Default Initialization of DPM particles for transient simulation
Benjamin Ortner
ortb is on a distinguished road
my job is to investigate transient effects within a pulverized fuel combustion case.
My previous approach was to start from a converged steady state case, switch to transient and just let the simulation run. The problem is, as the domain is very large, it takes an awful amount of time steps until the domin is filled up with particles and a "steady state" is reached. I am not interested in the initial ignition.
Is there an efficient way to initialize particles (position, velocity, mass, diameter, volatile component etc.) in a transient simulation? I read about initializing from a file, but that seemingly does not allow all necessary parameters.
Thank you for your advice!
Regards
Benni
ortb is offline   Reply With Quote
Old   July 9, 2022, 16:57
alainislas's Avatar
Alain Islas
alainislas is on a distinguished road
You are right, when solving reacting dpm cases in Fluent, it looks like only the non-reacting properties can be used in the file-injection (see pic). This is a problem that I have faced as well.
As of now, at least this metthod is better than injecting the particles from the inlet and waiting for them unitl they travel all throughout the domain.
alainislas is offline   Reply With Quote
dpm, initialisation, initialization, particle, udf
UDF in case with DPM modle POSTHU Fluent UDF and Scheme Programming 0 March 3, 2021 08:21
Counting Particles in Transient Simulation Nuuu CFX 14 October 8, 2020 19:19
finite values inside the simulation domain with hybrid initialization at t =0 sgbaek FLUENT 0 February 15, 2018 19:45
spray simulation with heat transfer using DPM Tensian Fluent Multiphase 1 June 7, 2016 05:57
Unsteady Injection (DPM) for certain amount of particles Gold FLUENT 0 October 18, 2011 14:15
