May 20, 2022, 00:59 |
Issue in coupled thermal boundary condition
Wade Lin
I'm trying to model a transient flow on a solid surface with a surface reaction. The reaction decomposes the fluid and generates heat, which transfers to the bulk and solid by convection and conduction. I used the multiphase model (fluid and air) to simulate the flow motion, which was quite successful. However, when I tried to apply the heat generation, it failed. I created the flow (mixture) and solid domains and applied a coupled thermal condition to the interface (surface and surface-shadow). Then, I assigned an expression like the below to the heat generation term with a specific wall thickness. Since the surface reaction only occurs when the fluid is in contact with the surface, I need to detect the existence of the liquid by using Volumefraction(phase='fluid'). Heat Generation: 1000 [kg m^-1 s^-3] * Volumefraction(phase='fluid') The syntax is correct, but the program showed a Message from the Cortex Process: Compute processes interrupted. Processing can be resumed. I think the problem is at the surface boundary. Because surface boundary is connected to the solid domain, the value of Volumefraction(phase='fluid') is invalid. Also, this function works if I only applied to the surface-shadow boundary. Hence, I think this is where the issue was created. Is there any method to fix it or avoid it? Thank you very much. This is the result I achieved by neglecting the solid domain, so there should be only convection on the surface: https://youtu.be/Qy7si7MHgIs |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 14:55 |
Thermal Coupled wall Boundary condition - Fluent | archeoptyrx | ANSYS | 0 | June 1, 2017 19:47 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
thermal boundary condition at coupled wall | gokul patil | FLUENT | 2 | June 19, 2014 06:07 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 18:11 |
