Periodic Boundary condition specifying the pressure gradient |
April 29, 2022, 07:51 |
I am trying to simulate multiphase flow through a pipe, using periodic boundary condition. I want to specify pressure gradient in the periodic boundary condition to have mass flow rate as an output. However, doing this i am not able to initialize from the periodic as i would usually do when specifying the mass flow rate, and also where do i define the volume fraction when i use periodic boundary condition? Hope someone can help thank you |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
viscosity udf don't use correct temperature and strain rate | rezvani | Fluent UDF and Scheme Programming | 8 | May 27, 2021 06:40 |
Fail to converge when solving with a fabricated solution | zizhou | FLUENT | 0 | March 22, 2021 07:33 |
Turbomachinery Mass imbalance | sheaker | CFX | 12 | September 5, 2019 09:09 |
question regarding LES of pipe flow - pimpleFoam | Dan1788 | OpenFOAM Running, Solving & CFD | 37 | December 26, 2017 15:42 |
