April 15, 2022, 16:19 |
Floating point Exception error in fluent
Nima
Rep Power: 4 |
Hi all.
I am working on a venturi tube in which Water is coming from inlet 1 (main inlet) and air from inlet 2 (Neck). After transferring mesh from ICEM in checking mesh of Fluent: This warning appears: "number of left-handed faces detected on zone x is not equal to the number of Right-handed faces on zone x. (Attached below) Model Multiphase VOF and CLS No mass and energy transfer. I initialized using standard from inlet 1. Then to run calculations it stopped with "floating point exception" error. I surmise the problem is with my mesh. Does anyone know how to solve this to avoid floating point exception error while calculation? Thanks in advance |
April 29, 2022, 06:34 |
#2 | |
Neeraj Kumar Vidhyarthi
Rep Power: 4 |
April 29, 2022, 11:20 |
Nima
Rep Power: 4 |
Hi dear NSTD,
Yes. Actually I used fill by caps in design modeller and in ICEM, the only block contains all the fluid volume. There is one body I named FLUID DOMAIN. Thanks |
icem, meshing, vof, zero floating exception |
Floating Point exception (core dumped) chtMultiRegionFoam | ayu12 | OpenFOAM Running, Solving & CFD | 1 | October 12, 2021 12:31 |
Floating point exception during parallel mode of fluent | aamer | FLUENT | 10 | May 16, 2019 10:49 |
icoFoam floating point exception (8) | leizhao512 | OpenFOAM Running, Solving & CFD | 7 | November 1, 2018 12:43 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 14:41 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 23:56 |
