Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Steam Jet Simulation
Old   April 6, 2022, 07:50
Default Steam Jet Simulation
Yaisel
Yaisel is on a distinguished road
Hello everyone,
I'm simulating steam injected horizontally through a nozzle into a water bath. My problem that I have is that the energy residuals start to increase and go up to more than 10e+25. Why could it be that I am having this problem?
My model conditions are as follows:
-Solver Pressure-Based
-Steady State simulation
-Gravity in the direction -y
-Eulerian Multiphase Model, Implicit Formulation
-two phases (water-liquid and water-vapor like ideal gas)
-Drag Coefficient (symmetric)
-Heat Transfer Coefficient (two-resitance, hughmark for liq and zero-resistance for vap)
-Mass Transfer Mechanism (evaporation-condensation with Thermal Phase Change Model)
-Interfacial Area (ia-particle)
-k-epsilon Realizable
-Saturation Temperature = 416.76K
-Saturation Pressure = 0.4 MPa
Boundary Conditions:
-Pressure-Inlet
Gaude Total Pressure (0.4 MPa)
Supersonic/Initial Gauge Pressure (0.399 MPa)
Volume Fraction Vapor = 1
-Pressure Outlet
Gauge Pressure (10200 Pa)
Backflow Volume Fraction Vapor = 0
Temperature (300 K)
All others boundary are trated like wall
Solution Methods:
-Pressure-Velocity Coupling Scheme = Phase Coupled SIMPLE
-Spatial Discretization is First Order Upwinde, xcept for Pressure which is Second Order and Gradient which is Least Squares Cell Based
If anyone can help me I would be very grateful.
Thanks!!
Yaisel is offline   Reply With Quote
condensation, energy residuals, steam jet, water
Maximum velocity decay in 2D wall jet simulation Cryo1991 FLUENT 9 March 6, 2023 09:24
Water jet simulation harry123 STAR-CCM+ 10 November 28, 2020 19:51
Simulation of Axisymmetric jet flow in openfoam gunvirs OpenFOAM 0 July 4, 2016 05:08
pressure equation in Jet simulation kumar OpenFOAM Running, Solving & CFD 0 June 9, 2010 13:18
UDF for synthetic jet simulation Chicken Fluent UDF and Scheme Programming 5 March 18, 2010 06:44
