Multiphase Flow Problem in Shell and Tube Heat Exchanger |
March 30, 2022, 06:39 |
Pakistan
Rep Power: 4 |
Hi all!
I am trying to run multiphase VOF simulation. I am working on simulation of Heat transfer in Shell and Tube Heat Exchanger 3D problem. The length of Shell and Tube Heat Exchanger is 22ft. The inner diameter of shell is 2.25in and tubes inner diameter is 0.56in. At first, I am considering the Shell fluid propylene is at constant temperature -50F so there is no fluid inlet and outlet in shell. I will model baffles and multiple passes later. Ethylene enter in tubes at 160F. The saturation temperature of ethylene is -43F at 197psi. I defined ethylene vapor and ethylene liquid properties in ansys fluent -> setup -> materials. When I turn the multiphase model ON with VOF then only mixture can be selected in Cell zone conditions and and Boundary conditions. Q1. How can I separately define the propylene in shell domain and ethylene in tube domain with multiphase VOF on? Q2. How can I consider the propylene as static fluid in shell? Screenshot (39).jpg Screenshot (40).jpg Screenshot (41).jpg Screenshot (42).jpg Screenshot (43).jpg |
April 29, 2022, 05:48 |
#2 | |
Neeraj Kumar Vidhyarthi
Rep Power: 4 |
heat exchanger two fluids, multiphase flow, multiphase mixture |
Problem setup and Boundary conditions for a heat exchanger using supercritical CO2 | orange20 | FLUENT | 0 | October 5, 2019 17:41 |
What is the boundary condition for shell and tube heat exchanger ? | miftahazhar | FLUENT | 0 | July 14, 2019 01:52 |
Defining Boundary Condition of Simulation of Shell and Tube Heat Exchanger ? | miftahazhar | FLUENT | 0 | June 26, 2019 10:34 |
CFD Fluent tutorial - Shell and tube heat exchanger - PROBLEM | tom96 | FLUENT | 1 | May 21, 2018 00:24 |
How to carry out 3D shell and Tube Heat Exchanger analysis in fluent | medogalal | FLUENT | 3 | December 30, 2015 04:28 |
