Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
define mass transfer rate in solidification/melting with DEFINE_MASS_TRANSFER macro
Old   March 4, 2022, 05:23
Default define mass transfer rate in solidification/melting with DEFINE_MASS_TRANSFER macro
Severin FENG is on a distinguished road
Hello, can anybody check my idea?
I try modelling a solidification/melting process for a moving alloy. Since I need to simulate the movement of solid thus the solidification/melting model in Fluent is not appropriate and I directly use VOF and define the solid phase as a high viscosity fluid.
I know that for the mass transfer between two phases I should use the macro DEFINE_MASS_TRANSFER. However, the example given by ANSYS doesn't consider the conservation of energy (it's likely a simplified LEE model).
So, my question is if it's reasonable to define the mass transfer in a two-phase cell between the two phases according to the heat flux from the neighboring cells because the convection effect is neglectable in the nearby region of the solid-liquid interface? Then in this way the mass transition rate is
m^{.} = \sum q /L
Severin FENG is offline   Reply With Quote
Problem with total heat transfer rate aswathy_raghu FLUENT 9 April 21, 2022 11:36
Laminar Kinetic Energy Model (Walters 2008) logoswort Fluent UDF and Scheme Programming 2 May 19, 2017 20:41
Problem with total heat transfer rate aswathy_raghu FLUENT 0 July 26, 2016 08:39
Missing math.h header Travis FLUENT 4 January 15, 2009 12:48
particle, parcel and mass flow rate balance flybird FLUENT 0 May 24, 2007 11:44
