Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Fluent not recognising adaptive mesh command
Old   February 28, 2022, 08:46
Default Fluent not recognising adaptive mesh command
Lauren Dransfield
ld1305 is on a distinguished road
Hi all,
I've been putting a journal together in Fluent 2020R2 which I'm hoping will essentially just fill a dry dock with water (attached image). I'm getting an error when I try to run the line:
/mesh/adapt/predefined-criteria/multiphase/vof 0.01
Fluent is telling me that this is an invalid command, however according to the documentation it should work. Similarly, the following comes up as an invalid command also:
/mesh/adapt/adapt-mesh
The journal (attached) sets up the VOF model and adds in the initial water level prior to this line. When I plot the water volume fraction it's in the right place (attached image).
If I use the GUI I can select the model and it's fine - interestingly the TUI command then works.
I wondered if anyone had any idea why it might not be working in the first instance?
ld1305 is offline   Reply With Quote
fluent, tui, vof
Error estimator - adaptive mesh - Ansys Fluent Nathália FLUENT 2 September 15, 2021 09:30
Adaptive mesh pressure gradient fluent DrMrBaki FLUENT 0 June 16, 2021 16:03
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 05:26
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
