Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
water in tank with vortex baffles
Old   February 8, 2022, 10:34
Default water in tank with vortex baffles
Shamoon Jamshed
Shamoon Jamshed is on a distinguished road
Send a message via Skype™ to Shamoon Jamshed
I am modeling a tank filled with water but pressurized with air at 5 bar. The outlet of the tank is equipped with a vortex breaker that is used to block unwanted air pockets to pass through. Therefore, the water should pass only.
Now , I am modeling the problem with VoF (explicit) . Phase 1 is water, phase 2 is air. Operating pressure is 5 bar. At outlet mass flow inlet for phase-2 is applied, like as if the water is going to some other source. MFR is 26kg/s. I first patch initial volume of phase 2 (air) to be like 70%. But the fluid water is not changing its position at all. That is, it remains 30%.
Please help in this problem
Regards,
SJ
Shamoon Jamshed is offline   Reply With Quote
Simulating water movement up and down in a tank walte ANSYS 1 October 19, 2018 14:38
Setting Up a case on building an empty tank with water going into the tank Nori4U OpenFOAM Programming & Development 1 May 8, 2015 03:10
Water tank baffles - modeling the flow with tank half full A_Prakash CFX 11 January 1, 2015 11:43
[GAMBIT] Water Slosing in Water Tank iwan ANSYS Meshing & Geometry 4 October 17, 2013 19:25
Simulating a tank filled with water and injecting vapor into it belkadi OpenFOAM 3 May 24, 2013 05:43
