Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
How to define oil as disperse phase and water as continuous phase on same inlet?
Old   February 2, 2022, 18:46
Post How to define oil as disperse phase and water as continuous phase on same inlet?
Muhammad Atif
m.atifme20 is on a distinguished road
I am very new to multiphase analysis. I am running an analysis of a control valve with oil in water as fluid. I understand how to define boundary conditions for multiphase inlet but when I run analysis both phases are uniformly mixed at inlet, however, in reality there are oil droplets in the upstream pipes that pass through the valve body and break down into smaller droplets.
Is there a way to define oil droplets coming from inlet? currently, I am just defining velocity and volume fraction and you can see the picture attached that the flow is uniform near the inlet side and later oil starts accumulating on the top side.
Any suggestion would be highly appreciated.
Thanks
Muhammad
m.atifme20 is offline   Reply With Quote
inlet bc, multiphase boundary, oil and gas
Mass imbalance problem in multiphase water and steam CFX case Antech CFX 1 October 26, 2020 05:03
No liquid water exist in my Fuel Cell simulation fatchang FLUENT 19 October 15, 2018 15:27
Modelling 2 phase flow (oil & water) in a pipe Ash95 STAR-CCM+ 0 August 4, 2016 11:13
Two phase flow of air and water with two inlet amin.shuvo FLUENT 5 August 18, 2015 06:49
Problem of simulating of small droplet with radius of 2mm liguifan OpenFOAM Running, Solving & CFD 5 June 3, 2014 03:53
