Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
FLUENT VOF -simulation metal rod melting problem
Old   January 28, 2022, 07:06
Default FLUENT VOF -simulation metal rod melting problem
Lab_001 is on a distinguished road
Hi
I use FLUENT VOF to simulate a steel rod shape changing during melting process.
My simulation condition:transient,VOF(steel-air),UDF(surface tension,recoil force in xyz direction),gravity.
In the project,the steel rod change its shape in temperature 300K. The material setting steel's melting point is 1700K. I think steel in temperature of 300K should be solid in my case,and would not have shape changing.
Is it possible for a material change its shape when its temperature is below melting point in vof model? Or I set something wrong?Could someone please help me with it? Thank you.
Lab_001 is offline   Reply With Quote
problem of running parallel Fluent on linux cluster ivanbuz FLUENT 15 September 23, 2017 20:12
Transient mode simulation (VoF model) mesh independence study problem yulu FLUENT 4 September 20, 2016 18:30
Desuperheater simulation problem in fluent kortaz System Analysis 0 April 20, 2016 06:03
Melting Simulation by Ansys Fluent mohammad razzaghian FLUENT 0 July 25, 2014 18:37
Simulation of Two Phase Fluid Flow Problem Using Fluent 5.0 Mohammad Al-Shannag Main CFD Forum 1 July 16, 1999 12:28
