Force applied onto a moving wall, which moves the fluid |
Omar
Rep Power: 0 ![]() |
I need help with my project. I want to simulate the doctor blading process in 3D. In the project, there is a force F on the doctor blade that causes the doctor blade to move. The doctor blade then brings the fluid into the cavity and stops after it passes through the cavity. I have an already finished 2D simulation, but there the doctor blade was set as a moving wall and its motion profile was entered with "dynamic mesh", with no force applied to the doctor blade. Also, for numerical reasons, which I would like to know, the doctor blading process was modeled with a gap d between the doctor blade and the substrate. The gap must be at least the size of two cells, otherwise the moving doctor blade will cause problems with remeshing. - I would like to know if I can enter the force F acting on the doctor blade into Ansys fluent. - Also, I would like the gap between the doctor blade and the substrate to become d=0. - The material of the doctor blade should also be entered into the simulation. I would be grateful if someone could tell me if and how I can solve these problems. |
force-driven, moving body, multiphase |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 10:00 |
Moving wall in fluid .wbpj example needed | Wannberg | ANSYS | 0 | September 8, 2016 05:04 |
Multiphase simulation of bubble rising | Niru | CFX | 5 | November 25, 2014 13:57 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
