Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Moist air condensation modeling for heat exchanger
Old   November 18, 2021, 15:43
Question Moist air condensation modeling for heat exchanger
Ravi Patel
rdp5252 is on a distinguished road
Hello, I was wondering how it would be possible to model cooling of hot exhaust (modeled as moist air) with dehumidification (condensation formation)? I am an absolute beginner at modeling multiphase flows but I have used Fluent in the past to model single phase flow of air. The reason I need help on this is because I am trying to find the overall heat transfer coefficient (U value) between the moist air traveling past the surface of a heat exchanger with a cold fluid traveling in the heat exchanger. After I find the U value, I am able to find the required heat transfer surface area based off of the cooling load and LMTD. I modeled this using moist air without condensation but I would like to try to validate my results using ANSYS Fluent because I know that condensation on the surface of the heat exchanger would increase the film coefficient of the moist air. I attached some pictures of the hand calculations I used to find the required cooling load and the excel calculator. If someone could help me get started on this it would be much appreciated.
rdp5252 is offline   Reply With Quote
condensation, heat exchanger, heat transfer coefficient, moist air, multi phase
Condensation of humid air on a cold surface (VOF - Lee, species transport) Tarantino Fluent Multiphase 1 October 21, 2024 07:38
Non-equilibrium condensation modeling using UDS and UDms toolpost Fluent UDF and Scheme Programming 2 June 14, 2022 06:08
Air Condensation Over Wings M MOHSIN Main CFD Forum 0 September 10, 2016 14:49
Evaporation & condensation in 2D Heat Exchanger Somnath rangrej Main CFD Forum 0 December 8, 2015 12:25
moist air density rafat Main CFD Forum 5 June 13, 2001 22:36
