Multiphase problem with multiple zones : Picture attached |
November 18, 2021, 08:03 |
Rabi Pathak
Rep Power: 6 |
I have a steel plate where the bottom wall is heated. Above this solid plate, a water filled zone is there which is contained by side adiabatic walls made up of steel. Above this static water zone, a zone filled with air is present. The air is incomming and outgoing as shown in figure.
The air is modelled as a species with combination of dry air+ water vapour. The water is also getting evaporated based on pressure difference and vapor formed is getting mixed in the air zone. Note : 3 frozen body are made in the design modeller and then all are made as form new part. Can anyone guide me how to do this? IMG_20211118_172242.jpg |
November 18, 2021, 14:04 |
Why don't you try this case in OpenFOAM. It should be relatively easy.
November 19, 2021, 00:17 |
Rabi Pathak
Rep Power: 6 |
November 19, 2021, 01:36 |
Hai Rabi,
Here is the link, its exactly same as your problem. https://www.youtube.com/watch?v=iORJt7Jb6oA Good luck |
November 19, 2021, 08:48 |
#5 | |
Rabi Pathak
Rep Power: 6 |
Thank you so much, it seems really helpful. I will try it and let you know about it |
problem with interfoam on multiple nodes | gkara | OpenFOAM Running, Solving & CFD | 1 | July 6, 2016 10:17 |
The problem of Stiff Chemistry Solver in Multiphase model | shenzhou1987 | FLUENT | 1 | January 11, 2016 03:52 |
[ICEM] Problem in creating different zones in ICEM-CFD | samurai_01 | ANSYS Meshing & Geometry | 2 | November 28, 2012 13:41 |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 13:21 |
problem with MFR model for multiphase mixing tanks | Srinivas | Main CFD Forum | 1 | November 7, 2005 15:16 |
