Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Reversed flow in faces on pressure outlets
Old   October 22, 2021, 05:22
Default Reversed flow in faces on pressure outlets
SBCR01 is on a distinguished road
I am simulating a 1-meter height 0.15-meter diameter of a cylindrical bubble column reactor. where the liquid is the primary phase and the air is the secondary phase. After initialization air is patched from 0.3 to 1 meter of column remaining water is filled initially from 0 to 0.3 meters of the column. While running the simulation, a message is shown that reversed flow in faces on pressure outlet in each iteration. Why is showing? please explain it?
SBCR01 is offline   Reply With Quote
air-water, bubble columns, multiphase flow
[snappyHexMesh] snappyHexMesh stuck when snap is turned on yukuns OpenFOAM Meshing & Mesh Conversion 3 February 2, 2021 14:05
[snappyHexMesh] Help with Snappy: no layers growing GianF OpenFOAM Meshing & Mesh Conversion 2 September 23, 2020 09:26
reversed flow in xxxx faces on pressure outlet franzdrs FLUENT 8 January 4, 2020 21:12
[snappyHexMesh] SHM Layer Addition Phase dickcruz OpenFOAM Meshing & Mesh Conversion 4 November 1, 2018 08:05
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 14:19
