Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Incomplete dpm vs. Y+
Old   September 22, 2021, 13:58
Default Incomplete dpm vs. Y+
Jack Lavender
jlavender is on a distinguished road
I am tracking particles through a closed volume using the k-epsilon turbulence model with enhanced wall treatment. Setting a y+ value of 1.0 I get a first layer thickness to use at the walls.
I have significant numbers of incomplete particles getting stuck in very low velocity cells next to the walls.
Can I reduce the y+ value so that the first layer is thinner and the particles won't get trapped? I haven't found any documentation giving a minimum value of y+.
Thanks, Jack
jlavender is offline   Reply With Quote
dpm, enhanced wall function, k-epsilon model, y-plus
Incomplete DPM Mohsin FLUENT 1 February 23, 2019 12:25
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
Problems building Paraview 3.12 on Gentoo Linux pajot OpenFOAM Installation 11 April 11, 2013 09:09
how to get infos of DPM -- incomplete particle tommyan Fluent UDF and Scheme Programming 2 March 15, 2013 09:44
[swak4Foam] installing funkySetFields igo OpenFOAM Community Contributions 1 November 20, 2012 21:16
