Horizontal water stream profile out of a nozzle |
August 16, 2021, 07:01 |
Babak B.Chehreh
Dear all
I am new to multiphase simulation and I have been searching a lot to find a similar problem to figure out the setup but since it's simple (or not interesting enough) I haven't been able to. This is the Problem: water comes out of a 2mm nozzle with 5 m/s velocity, horizontally into atmosphere. the goal is to capture the profile of the water curve until it reaches the ground in air crossflow with different velocities ranging from 0.5 to 3.5 m/s. for the first step to find the right setup I am trying to simulate it without cross flow and in 2D planar. this is the setup that I am using: - Multiphase VOF model (Implicit formulation) - k-e Realizable turbulence model - non-iterative time advancement - PISO pressure-velocity Coupling - Spatial Discretization : - Gradient: Green-Gauss Node based - Pressure: Body Force Weighted - Momentum: Second Order upwind - Volume Fraction: Compressive - Turbulence: First order Upwind This particular setup is the only one that results in a stable behavior of water stream. but the problem is water profile is not right. with a simple experiment we know that water should reach the ground in around 1.5 meters but with this setup it goes out of the domain (travels way more than it should!) (please see the picture). I have also used dynamic adaption for mesh using ISO-Value , to refine mesh where the water is. (please see the pictures). Any ideas are appreciated greatly. please don't hesitate to ask for any info. that I have missed presenting. Thank you so much. |
fluent, gravity force, planar jet, water + air |
Water surface Profile Before Ogee Spillway | bejanyar | Main CFD Forum | 0 | May 15, 2017 05:20 |
initialize open channel flow with a know water surface profile | Ema40 | Fluent Multiphase | 4 | February 21, 2016 12:31 |
3D-Simulation of Water Flow From Nozzle into Air | Navin Sampath | FLOW-3D | 2 | February 26, 2009 11:46 |
compressible flow in a counterflow nozzle | d.vamsidhar | FLUENT | 0 | November 24, 2005 02:45 |
water spray nozzle | Dr. Insoo Cho | Main CFD Forum | 3 | October 15, 1999 15:53 |
