July 4, 2021, 04:26 |
Rotating Heat Pipe Help
LT
Rep Power: 5 |
Hi. I am simulating a rotating heat pipe with phase change. It is divided into three sections, evaporator, adiabatic part and condenser. I have an initial fill ratio of 8% liquid. I have big problems for phase change. Using Lee's model either via UDF or as a standard fluent model I cannot observe the phase change. I also have problems with turbulent viscosity instability which leads me after a short while to Courant Number over 250 and diverging solution. Do you have any suggestions? My idea is to implement a new multiphase model, Sun's model via UDF, as mentioned in the paper I am referring to. Big problem is the inability to write the udf of this model, do you have any suggestion or help to give me please? I will leave the model below.
condensation model, evaporation condensation, heatpipe, multiphase, udf |
Lee model in heat pipe application | arunraj | FLUENT | 0 | May 20, 2020 00:47 |
Conjugate Heat Transfer in rectangular pipe with cylindrical pins | PabloXX37 | System Analysis | 0 | November 20, 2019 09:46 |
need help about double pipe heat exchanger with chtMultiRegionSimpleFoam | wuyangzhen | OpenFOAM | 10 | December 12, 2017 00:19 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Heat Transfer in a pipe flow(hot air) | Saima | Main CFD Forum | 0 | January 17, 2011 07:08 |
