Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
PBM changes the multiphase flow
Old   June 30, 2021, 07:25
Default PBM changes the multiphase flow
Philip
philipxyz is on a distinguished road
I'm currently simulating a multiphase flow in 2 phases with pbm. phase 1 is gasoline and phase 2 is water. The goal is to simulate an emulsification process with water as the dispersed phase.
As my multiphase model I'm using the Euler and Mixture model to compare them. (see attached screenshots)
In the beginning I was simulating the flow without any PBM activated, just So I know that it is running stable. The Problem is that as soon as I activate the PBM my flow pattern changes completely, while it is still running stable and converging.
So the question is if anybody knows why the flow pattern changes or how to fix it.
Thank you
philipxyz is offline   Reply With Quote
Old   July 2, 2021, 05:25
DCT
DCT is on a distinguished road
That looks rather odd. Is the simulation in 2D? And are the droplet sizes with the PBM comparable to your earlier solution? Did you set boundary conditions (incl. inlet droplet size) properly?
DCT is offline   Reply With Quote
Old   July 2, 2021, 06:03
Philip
The simulation is in 3D, the screenshot is on a plane.
I hope my BC are set properly. I've followed the fluent theory guide. I have two velocity inlets and a pressure outlet.
Walls etc. are set properly.
I haven't changed any conditions on the two simulations except activating the PBM.
Old   July 6, 2021, 07:05
DCT
can you show a plot of droplet sizes compared to see how they compare to earlier settings? And how are the residuals doing, is everything converging?
Old   July 7, 2021, 04:56
Philip
Thank you for your help.
In the meantime I solved or rather know what the problem is. I just didn't anticipate the amount of changes that come in top play with different bin sizes, like drag and non-drag forces, surface tension etc.
multiphase flow adjoint solver ThibautDalemans FLUENT 0 December 18, 2019 04:51
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow Jing Main CFD Forum 8 October 5, 2018 18:02
multiphase flow ,mass and volume fraction imbalance sope111 CFX 16 September 3, 2018 01:10
Review: Reversed flow CRT FLUENT 1 May 7, 2018 06:36
Multiphase flow in a pipe with a CHT wissal CFX 4 June 12, 2017 13:15
