Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Mixing process with eductor nozzles
Old   May 13, 2021, 21:47
Default Mixing process with eductor nozzles
ryupa's Avatar
Renatto Yupa Villanueva
ryupa is on a distinguished road
Hi everyone!
Someone has already performed a simulation of multiphase mixing process in a tank using eductor nozzle?
I was trying to configurate a computational case in Fluent, incorporating momentum sources as a ventilation problem using jet-fans, but withour success.
I share a photo of the problem that I would like to solve.
ryupa is offline   Reply With Quote
Parallel fluent process exiting before reading the mesh file harsha2398 FLUENT 3 December 29, 2020 01:58
Inlet Mixing at 1D Numerical Model | Stratified Storage HumanistEngineer Main CFD Forum 26 July 30, 2018 11:41
The fl process could not be started because of UDF majid_kamyab Fluent UDF and Scheme Programming 6 December 15, 2015 09:42
Mixing process paul115 Fluent Multiphase 11 September 3, 2015 17:39
error 262144 and unexpected disconnect when run on 2 nodes Emily1412 SU2 Installation 1 April 10, 2014 18:08
