Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Divergence detected in AMG solver. VOF.
Old   May 7, 2021, 01:02
Default Divergence detected in AMG solver. VOF.
Mr.Mister is on a distinguished road
Hi guys. I'm simulating air-water flow through a T pipe with 26mm inner diameter. The pipe was created in a 2D domain, there are two inlets (one for air and the other for water) and one outlet. The two inlets have velocity inlet conditions and the outlet has pressure outlet conditions. The pipe is filled with water and then water and air start to flow from the inlets with their respective inlet velocities. I'm conducting a mesh independence test with four meshes. The time-step for each mesh was calculated based on the CFL condition and the total flow time for each one was 6 seconds. The first three simulations had no problems but the fourth one is presenting the following problems after the bubbles reach the outlet (which occurred approximately in 2,3 seconds):
# Divergence detected in AMG for x-momentum: protective actions enabled!
# Divergence detected in AMG for x-momentum, temporarily solve with BCGSTAB!
Divergence detected in AMG solver: x-momentum# Divergence detected in AMG for y-momentum: protective actions enabled!
# Divergence detected in AMG for y-momentum, temporarily solve with BCGSTAB!
Divergence detected in AMG solver: y-momentum# Divergence detected in AMG for pressure correction: protective actions enabled!
# Divergence detected in AMG for pressure correction, temporarily solve with BCGSTAB!
Divergence detected in AMG solver: pressure correction# Divergence detected in AMG for pressure correction: protective actions enabled!
Divergence detected in AMG solver: pressure correction# Divergence detected in AMG for k: protective actions enabled!
# Divergence detected in AMG for k, temporarily solve with BCGSTAB!
Divergence detected in AMG solver: k# Divergence detected in AMG for omega: protective actions enabled!
# Divergence detected in AMG for omega, temporarily solve with BCGSTAB!
Divergence detected in AMG solver: omega
reversed flow in 118 faces on pressure-outlet 9.
Error at host: floating point exception
Error at Node 0: floating point exception
Error at Node 1: floating point exception
Error at Node 2: floating point exception
Error at Node 3: floating point exception
Error: floating point exception
Error Object: #f
I checked the mesh quality and it looks good (min orthogonal quality = 0.68; max skewness = 0.60; max aspect ratio = 10.07). I tried to solve the problem by reducing the time step in half and decreasing the relaxation factors, but it didn't work. I don't know how to fix this problem, so I really need some help and I'm open to answering any questions. I'm going to list every piece of information I find relevant about the simulation.
General:
Parallel
Solver type: Pressure-Based
Time: Transient
Planar 2D space
Gravity on
Models:
Multiphase VOF with explicit formulation and Surface Tension Force Modeling (CSF)
Default Courant number: 0,25
Implicit Body Force
Turbulence Model: SST k-omega
Cell Zone Conditions:
Specified Operating Density: 1.225 kg/m³ (air density)
Boundary conditions:
air inlet velocity = 0.123 m/s
water inlet velocity = 0.6 m/s
outlet Gauge Pressure (pascal) = 0
pipe wall: stationary, no slip
Solution Methods:
PISO Scheme
Least Squares Cell Based Gradient
PRESTO! Pressure
volume fraction: Geo-Reconstruct
Momentum, Turbulent Kinetic Energy and Specific Dissipation Rate = Second order upwind
Transient Formulation = First order implicit
Solution Controls: Default
Residuals = 10e-5
Standard initialization with default initial values
Mr.Mister is offline   Reply With Quote
Old   May 17, 2021, 15:07
Question
Maharshtra
Harshad Bhalerao is on a distinguished road
You got the solution of this problem ?
Harshad Bhalerao is offline   Reply With Quote
Old   August 31, 2021, 20:42
Hi Harshad Bhalerao,
I still dont know the answer. It has been months since i posted this and nobody posted a reply.
Old   September 21, 2022, 05:34
CHEN TING
CHEN TINGSEN is on a distinguished road
can you solve it
CHEN TINGSEN is offline   Reply With Quote
Old   September 25, 2023, 08:10
Default AMG solver divergence
Outside North America
Tian Hongkang is on a distinguished road
Error Object: #f
General:
Parallel
Time: Transient
Planar 2D space
Gravity on
Models:
Implicit Body Force
Solution Methods:
PISO Scheme
PRESTO! Pressure
Residuals = 10e-5
Hello, I recently encountered the same problem as you. Do you know the reason for this mistake? Thank you!
Tian Hongkang is offline   Reply With Quote
Old   November 22, 2024, 07:32
Default I am encountered with same problem did you get any solution
Rahul Vishwakarma
Rahul Vishwakarma is on a distinguished road
I recently encountered the same issue, did anyone know how to avoid this.
Rahul Vishwakarma is offline   Reply With Quote
amd divergence; vof; 2d
Jet impingement cooling error - Divergence detected in AMG solver: temperature riquelme FLUENT 0 December 30, 2019 08:19
Divergence detected in AMG solver: pressure correction xinquanzhoucn FLUENT 5 July 21, 2014 05:49
Floating point error and divergence detected aannjj FLUENT 0 July 2, 2013 04:44
Error: Divergence detected in AMG solver: x-momentum/ epsilon/ temperature bubuchacha FLUENT 6 February 26, 2013 04:30
Quarter Burner mesh with periosic condition SamCanuck FLUENT 2 August 31, 2011 12:34
