March 20, 2021, 13:17 |
VOF expression
Giovanni Fazzone
Rep Power: 5 |
I am working on a axisymmetric multiphase simulation (in the picture), about the impact of a droplet over a wall with dynamic contact angle, defined by this expression: IF(vrad>0,110[deg],65[deg]) Now, I want to define vrad (radial velocity) as the y velocity evaluated at the ymax. ymax is the max point over the wall where the phase 2 (water) is equal to 1. I don't know how to write in Fluent expression vrad and ymax. Can anyone familiar with the Fluent expression help me? Thank you |
March 22, 2021, 04:38 |
doctor
Jia
Rep Power: 5 |
could you share your UDF code, i have conducted relevant research before. I need to judge whether the logic is correct or not based on the statement before and after it and also the code can help me clearly understand your meanings. my email is 870254031@qq.com.
looking forward to your reply, because i also have some issues i'd like to discuss with you about droplet impacting. |
March 22, 2021, 06:05 |
#3 | |
Giovanni Fazzone
Rep Power: 5 |
March 22, 2021, 06:21 |
Jia
Rep Power: 5 |
March 23, 2021, 07:03 |
Giovanni Fazzone
Rep Power: 5 |
In latest Fluent version there is the function "expression" (https://www.ansys.com/blog/tips-and-...nsys-fluent-ui).
For instance, what I am trying to do, is using the IF function. IF(<expr>,<vector>,<vector>) If the first term is true, the output value is the first vector, if it is false, the output value is the second vector. IF(vrad>0,110[deg],65[deg]) so, if radial velocity is positive, the DCA is equal tto the advancing value (110° in my case), else is receding (65°). Unfortunately, I have not already found an efficient condition for the IF function. |
March 23, 2021, 07:50 |
Jia
Rep Power: 5 |
dear friend,
i have known your meaning, which attract me to discuss with you. i still have some questions: 1) i have read the link you gave, but i don't find the definition of "IF" function in the website, which is the most important to know. you'd better screenshot the definition of "IF" function from the HELP file. or you could tell me which version of the software, i will download the help file to find the definition. 2) your simulation is related to multiphase flow,water phase and vapor phase, so the definition of radial velocity is not clear, the software can't discern what is water, automatically. could you tell me where to set the dynamic contact angle in the software by screenshot? 3) i have the UDF about the dynamic contact angle, if you want, i could share it with you. but i still don't understand some codes in the UDF. |
March 23, 2021, 14:48 |
Giovanni Fazzone
Rep Power: 5 |
1) I am using the 2021 R1 version. I link the screenshot of IF statement from guide, but it is not different from what i wrote before.
2) In the software version that I am using, you can create some Named expressions (last menu in Setup). Then, when you select the contact angle between phases, you select the expression you created. 3) Please, yes share with me your UDF. Did you write it? My email is giovanni.fazzone@mail.polimi.it |
Outlet boundary condition in interFoam | Andrea_85 | OpenFOAM Running, Solving & CFD | 51 | July 20, 2017 14:31 |
writing execFlowFunctionObjects | immortality | OpenFOAM Post-Processing | 30 | September 15, 2013 07:16 |
How to install CGNS under windows xp? | lzgwhy | Main CFD Forum | 1 | January 11, 2011 19:44 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 07:25 |
Lift, Drag Vs time chart,calculations | Jamesd69climber | CFX | 8 | February 17, 2005 18:23 |
