March 15, 2021, 17:16 |
How to handle counterflow BC's
NM
Rep Power: 5 |
I've done plenty of CFD but never using a Eulerian-Eulerian model. The situation isn't complicated, but I don't understand how the BC setup would work. I have a fluidized bed in a channel. Particles (treated as a continous phase) fall at a known velocity down through the channel. Where the particles exit, air is injected counter (upward) to the particle flow and exit out the top (particle inlet). Is it even possible to set this up. If I make a velocity inlet for my particles, how can it possibly double as an outlet? Thanks for your help |
[solids4Foam] pointD BCs for FSI with fixedDisplacementZeroShear BCs | tschenkel | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 0 | November 17, 2019 09:39 |
How to set BCs programmatically | incompressible | OpenFOAM Programming & Development | 6 | November 20, 2017 03:47 |
Difference between HF and Temperature BCs | Catthan | FLUENT | 0 | August 7, 2013 06:59 |
Dealing with BC's in OF 1.6 | vkrastev | OpenFOAM Running, Solving & CFD | 5 | September 4, 2012 12:58 |
Understanding Code behind BCs | Linse | OpenFOAM Programming & Development | 8 | January 9, 2012 09:58 |
