February 24, 2021, 15:25 |
Archimedean screw on free surface simulation
sharif salhab
Hello everyone,
Using Ansys Fluent, I am trying to simulate an Archimedean screw sitting on the free surface (half submerged), to determine the thrust produced for a given set of dimensions. below is the setup and some of the problems faced, any help would be appreciated. Setup : - Transient + Gravity. -VOF/multiphase/no surface tension. - k-omega turbulence model. - Zones Conditions: Cylindrical enclosure of the screw (mesh motion-Rotating)/ rectangular enclosure medium (Static-2 Phases). - boundary conditions: pressure inlet/ pressure outlet/ atmosphere(pressure outlet)/ everything else is a static wall. - Methods: SIMPLE, all first order except the momentum 2nd order. Problems faced: - negative drag force and coefficient when monitoring. - Drag force taking too many iterations to settle down as if waves are produce initially ( given the small enclosure and the initial rotational velocity of the screw being 50rpm) - apparent gap at the interface region between rotating and static enclosures ( when looking at contour planes ). - high flow time needed to reach a settled flow (20 sec minimum, since my time step size is 0.01 to 0.1 with 20 iteration it takes a lot of calculation time) Also, given my application would you it be better to solve the problem as steady state? Thank you ! |
fluent, free surface, thrust, vof |
Questions about simulation free surface open channel flow by interFoam and pimpleFoam | IsanM | OpenFOAM Programming & Development | 0 | September 10, 2020 03:13 |
Free Surface Simulation in FLUENT | vavnoon | Fluent Multiphase | 5 | June 17, 2020 08:54 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
Problem Concerning free surface wave simulation | michaels | STAR-CCM+ | 3 | February 25, 2011 07:28 |
VOF simulation free surface caused by gas inject | rensb | FLUENT | 4 | July 20, 2006 04:45 |
