It is possible to use a DEM collision model to simulate the blockage of particles? |
February 23, 2021, 09:05 |
Abi
Rep Power: 6 |
Hello Everyone,
It is possible to use a DEM collision model to simulate the blockage of particles in a pipe. I am using DEM collision model, unsteady particle tracking ( particles diameter: 0.0012 with density of 2650 Kg/m^3’) and the gravity was activated, so the particles are falling in the axial direction. The pipe diameter = 0.003m, length L= 1m. The collision between the particle and the wall lead to deceleration of the particle, affected the arrangement of particle along cross section, this lead to form a stable arch. The jamming probability increases with the probability that a stable arch along the cross section of the pipe is formed. This already done in many previous studies with different commercial software’s but not with Ansys. In my case I have run 173 particles for 100000-time steps, with 0.00001s time step size. The calculation took extremely long time (more than 24 hrs. for 3% Iteration). The problem is to detect the collision, the time step must be very short within 10^-6 for a time-period of 5-10 sec. is possible to perform that with Ansys? I tried simple solution method for both first and second order for Turb. Kin., but I had kind of divergence for both, as shows in the attached residual. I appreciate any advice on setup and/ or parameter that can help in reducing the iteration time. Thanks in advance. Abi |
Modeling the gas flow through the packed bed of DEM particles | Legat | STAR-CCM+ | 6 | January 17, 2024 09:58 |
DEM collision model parameters | wim_1996 | Fluent Multiphase | 2 | January 21, 2021 10:30 |
Size distribution and collection of particles | Mu_CFD | CFX | 6 | January 11, 2021 22:00 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
How to tessalate STL model to cuboid particles? | Kamil Anderzhanov | Main CFD Forum | 1 | October 8, 2002 22:56 |
