Number of particle in DPM simulation is too high |
February 21, 2021, 13:15 |
Anshuman Sinha
Rep Power: 8 |
number tracked = 152387, escaped = 85, aborted = 0, trapped = 0, evaporated = 0, incomplete = 0, incomplete_parallel = 0. I have a simulation where I'm injecting particles at the bottom of a vessel, Why am I getting such a high number of particles in my simulation. I don't want such high numbers due to issues with max particle loading and continuity. I'm using surface injection with the inlet surface having 41 cell centers. Setup: Flow rate = 0.0009768 (kg/s) , Velocity = 0.1 m/s DPM iteration interval = 2, Unsteady tracking at fluid time step Fluid time step = 0.001 sec , Max iterations = 30. Thanks for the help. |
March 2, 2021, 05:30 |
ahmed elbanna
Rep Power: 10 |
I recommend you refer to documentation published by Ansys Fluent including the theory guide and user guide as they correlate the different models with the recommended operating range.
i have used dpm to simulate dilute flow with air at low ST you can refer to pepar (An experimental and theoretical study on particles-in-air behavior characterization at different particles loading and turbulence modulation) DOI ; https://doi.org/10.1016/j.aej.2019.04.002 |
dpm, multiphase |
[snappyHexMesh] snappyHexMesh stuck when snap is turned on | yukuns | OpenFOAM Meshing & Mesh Conversion | 3 | February 2, 2021 14:05 |
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) | AndreP | STAR-CCM+ | 10 | August 2, 2018 08:48 |
decomposePar -allRegions | stru | OpenFOAM Pre-Processing | 2 | August 25, 2015 04:58 |
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library | aylalisa | OpenFOAM Installation | 23 | June 15, 2015 15:49 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 06:12 |
