Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Iteration in DPM
Old   February 4, 2021, 14:54
Smile Iteration in DPM
Abi
Abeer is on a distinguished road
Hello everyone,
I am using DEM collision model where I predefined few particles with density of 2650 Kg/m^3 inside the pipe, The pipe diameter = 0.0042m, length L= 1m.
Particle initial conditions can be read from an external file. at time = 0, (334) particles are placed at random position within the pipe. The velocity of the particles in radial direction is chosen randomly from -v to v= 0.01, while the particle velocity in axial direction is set to zero.
The collision parameters for the collision pairs was Herzian_dashpot for normal contact force and friction_dshf_rolling for tangential force.
Periodic boundary condition is applied in the axial direction with specified air mass flow in same direction of zero Kg/s.
Transient model, with unsteady particle tracking, and the gravity was activated, so the particles are falling in the axial direction.
I have run 334 particles for 10000-time steps, with 0.0001s time step size. The solution was successfully converged, but the calculation time took extremely long time (more than 24 hrs. for 40% Iteration).
According to the calculation of collision time and martial properties mentioned above, I should use time step size about 10^-5, with 100000-time steps, which supposed to have longer iteration time.
I appreciate any advice on setup and/ or parameter that can help in reducing the iteration time. Thanks in advance.
Abi
Abeer is offline   Reply With Quote
DPM Iteration Interval ? ebtedaei FLUENT 1 April 12, 2018 13:17
Unusual long time for DPM iteration in Coal Combustion modelling srv1406 FLUENT 0 May 24, 2016 09:48
Hardware-Configuration for Fluent HPC-Pack (8x) JohHaas Hardware 9 March 3, 2015 14:25
DPM: Particle temperature at previous iteration step sega Fluent UDF and Scheme Programming 0 March 10, 2010 07:48
Parallel runs slower with MTU=9000 than MTU=1500 Javier Larrondo FLUENT 0 October 28, 2007 23:30
