Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Unable to patch Cell Registered Region to define phase for multiphase simulation
Old   February 1, 2021, 17:21
Default Unable to patch Cell Registered Region to define phase for multiphase simulation
Allen
allenpv is on a distinguished road
I have set up a multiphase model in Fluent with 2 phases (gas and liquid nitrogen)
I created a region in Adapt>Cell Registers>New Region
I used Save/Display to see the defined region and everything looks good
I initialized the domain using standard method with phase2 (liquid) volume fraction as 0 over the entire domain
I then patched phase2 (liquid) volume fraction as 1 in the defined region. Please find attached screenshot of this step. Please note that I have only selected the region and I have not selected the zone. I get the message (certain number of cells have been marked).
Next to verify if the patching was done correctly, I created a contour to show the volume fraction of phase2 (liquid) but the result shows the whole domain having 0 volume fraction (implying that the region patching did not work). There are no error messages.
Attached Figures:
Fig 1: Region created in Cell Registers and displayed
Fig 2: Patching region with phase2(liquid) volume fraction 1
Fig 3: Contour showing the whole domain have initial volume fraction value and patching did not take place
allenpv is offline   Reply With Quote
Old   February 14, 2021, 13:19
Allen
I was able to fix this by using the marked region to separate the single cell zone within Mesh>Zone>Seperate
Once I had two cell zones, I patched each zone with respective values of phase volume fraction and I could observe the result in the initial contour.
This however still does not explain why I couldn't achieve the same result just by patching the region. Confused (maybe a bug?).
multiphase, patching
[Other] Wedge patch '*' is not planar LilumDaru OpenFOAM Meshing & Mesh Conversion 7 September 18, 2024 06:52
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 06:37
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 12:04
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, cfdproject OpenFOAM Meshing & Mesh Conversion 0 April 14, 2009 16:45
Warning 097- AB Siemens 6 November 15, 2004 05:41
