January 5, 2021, 11:59 |
DEM collision model parameters
Wim Kleermaker
Hello everyone,
Currently, I am working on a project related to the numerical estimation of erosion in a centrifugal dredge pump. Since the volume fraction of the sand in this problem is between 0.01 and 0.1, I intended to use a four-way coupled (fluid-solid, solid-fluid, particle-wall, particle-particle) Eulerian-Lagrangian model as implemented in ANSYS Fluent (DPM model). For the collisions I want to use the DEM collision model, more specifically the linear spring-dashpot model with friction. For this model, a number of parameters have to be specified, including the coefficient of restitution, the friction coefficients (mu_stick, mu_glide and mu_limit) and characteristic velocities (v_glide, v_limit and slope_limit). Since there is no description in Fluent’s theory or user’s guide how to determine these parameters, I was wondering if anyone knows how to find the values for these parameters? Thanks in advance, Wim |
January 18, 2021, 09:00 |
Alexander
Rep Power: 10 |
you can search for them in the relevant literature
but in my case I had to select most of these parameters empirically based on physical experiments |
January 21, 2021, 10:30 |
Wim Kleermaker
Hey sfn,
Thanks for your reply! On what kind of experiments did you base the values of these parameters? Kind regards, Wim |
collision, dem, dpm, erosion, restitution |
Droplet Collision Model - No coalescing | Sripadaraja | Fluent Multiphase | 0 | September 12, 2018 02:07 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 15:32 |
About Collision Model | taksue | OpenFOAM Post-Processing | 6 | January 14, 2009 03:10 |
