Transient multiphase flow simulation inside a high l/d ratio pipe |
January 1, 2021, 13:52 |
Shahriar Mahmud
Rep Power: 10 |
I am planning to perform transient multiphase flow simulation inside a vertical pipe (water + Nitrogen) where the length to diameter ratio is around 10^4 (5000 ft long with a 0.5 ft diameter). While I found work been done with geometry of 10^2, some papers suggested 10^4 is too high and may cause divergence. I would like to ask the forum if you can shed some light on this i.e., why the solution may diverge, any trick you would like to suggest to successfully perform the simulation. Also, if you are aware of any such publication please let me know. In terms of resources, I will hopefully have high performance computational facility. So in terms of computational time, that shouldn't be an issue. Thanks. |
divergence, fluent, multiphase flow |
Nu values come up too high for cylindrical pipe turbulent flow | Onur10 | FLUENT | 7 | February 21, 2016 12:59 |
[ANSYS Meshing] Aspect ratio of 3D simulation of flow over turbine with k-omega, SST | TKP | ANSYS Meshing & Geometry | 0 | October 8, 2015 11:26 |
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC | Endel | OpenFOAM Running, Solving & CFD | 3 | September 11, 2014 16:29 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
