December 16, 2020, 05:02 |
PCM melting simulation giving weird results
carlo
Rep Power: 5 |
Hi everyone, I'm trying to simulate PCM melting in a parallelepiped enclosure (100x20x100 mm) heated from the side (100x100 face) with a costant heat flux. Since it seems a natural convection problem to me, I've activated gravity in the Y direction and used the Boussinesq approximation. The liquid density is 760 kg/m3 at 80°C and the solid density is 880 kg/m3 at 15°C, melting temperature being 41-43 °C. In order to use the Boussinesq approximation I've used a mean density and under "operating conditions" a mean temperature. I've tried different mesh size,as well as different timestep and iterations per time step. Other settings are as default. Evey time I get weird results, as you can see in attachment #2: when the liquid fractions get to 0.9, the PCM just melts instantly. If I use costant density, the I get small steps as you can see in attachment #3, so a less smooth rise but at least I don't get that jump at 0.9. Can you help me? Thank you
How to restart simulation using results from other solver | sahmed | OpenFOAM Running, Solving & CFD | 8 | July 5, 2019 06:02 |
Validation of 2D simulation and experimental results | mizzou | OpenFOAM Running, Solving & CFD | 8 | April 4, 2017 09:31 |
interrupt the simulation, check results, continue simulation | soulsaver | Phoenics | 1 | June 28, 2013 01:15 |
Simulation of microencapsulation PCM | rosol | FLUENT | 0 | March 22, 2008 07:23 |
simulation results for k-w model and SST model | Li | CFX | 7 | June 29, 2007 04:19 |
