Open channel flow simulation for turbomachinery |
December 9, 2020, 09:05 |
Khubaib
HI,
I am doing a simulation on Gravitational Water Vortex turbine, where the geometry of the setup is attached below. Boundary condition that i want are such that on the right hand side is the mass inlet of water, and the top surface is open to atmosphere. So, i am getting into trouble as to how should set my above boundary conditions respond to on these two surfaces in 'Fluent'. Part II Moreover, when i tried as Transient solution, with 0.1in element size (for reference the inlet dimensions are 7in x 7in)[140k elements], adaptive time settings my continuity didn't converge at all even after reducing the URF to 0.3 for momentum where on the other hand all other residuals had gone below 1e-4. Kindly help me out here. Thanks basin geometry 1.jpg Last edited by khubaibbb; December 9, 2020 at 09:15. Reason: forgot to add picture |
Interaction between open channel flow and porous flow | narendrapatel111 | ANSYS | 0 | June 8, 2020 11:42 |
Enabling Open Channel Flow Sub-Model in Mixture model | cod213 | FLUENT | 0 | January 10, 2017 13:40 |
Open channel flow simulation using VOF | rsaha | FLUENT | 5 | April 10, 2016 17:28 |
Problem compiling a custom Lagrangian library | brbbhatti | OpenFOAM Programming & Development | 2 | July 7, 2014 11:32 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 13:59 |
