November 26, 2020, 12:32 |
fluent species transfer
L.A.Isanka
Rep Power: 6 |
Hello!
I'm using the fluent species transfer model to see the particulate diffusion through a microchannel. The mixture contains carbon microspheres in an Ethyl Alcohol solution and I'm planning to build a model to see microspheres diffusion through the channel. But when I'm setting up with the species transport properties window, I can't access any solid material. Only liquid phase materials are visible. Can someone please help me fix this issue? Thank you! Regards, Achini Last edited by Achini; November 27, 2020 at 08:14. |
fluent, mixture material, species transport |
problems after decomposing for running | alessio.nz | OpenFOAM | 7 | March 5, 2021 04:49 |
What is the equation or formula to calculate Mass Flux[kg/m²s] of species in Fluent? | THA SEANGHAI | FLUENT | 0 | September 11, 2020 01:10 |
Heat Transfer Problem in FLUENT | eng_yasser_2020 | FLUENT | 3 | February 19, 2019 02:13 |
Erron: FLUENT received fatal signal (ACCESS_VIOLATION) in DPM Heat and Mass Transfer | Melvin | FLUENT | 2 | November 17, 2016 01:06 |
Fluent Multphase species transport | mcribas | Fluent Multiphase | 0 | October 3, 2016 09:09 |
