November 5, 2020, 15:58 |
Velocity Adjustment
Rep Power: 6 |
I am conducting simulations on eularian multiphase model. Initially, my whole domain was consisting of primary phase. Later on, I add source terms via UDF and generating secondary phase from the primary phase(phase transition). My question is this, are there any way to stop the velocity of the secondary phase which I generated? Meaning that, I want to keep my secondary phase motionless during its generation. In other words, I want it to treat like a solid. I have tried to DEFINE_ADJUST macro, and add second momentum sink term (first one was while generating the phase), but they did not work. Thank you very much! |
serial udf to parallel udf | radioss | Fluent UDF and Scheme Programming | 10 | January 19, 2019 08:56 |
wrong velocity contour of rotating propeller - Fluent | calv | FLUENT | 1 | September 6, 2018 11:48 |
Velocity in Porous medium : HELP! HELP! HELP! | Kali Sanjay | Phoenics | 0 | November 6, 2006 06:10 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
