Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
multiphase cell and face temperature
Old   September 12, 2020, 11:50
Default multiphase cell and face temperature
SAJA AL-RIFAI
sajaalrifai is on a distinguished road
hello,
I wrote a UDF to calculate face and cell temperature and use it to adjust some of the values using the Adjust function. In my case I have mixture of gases including the water vapor (phase 1) and water liquid (phase 2). My UDF should loop over the phase 1 to calculate condensation of water vapor on a solid wall using a specific functions. however, the problem is the cell temperature and face temperature is very high and I have very low condensation, when I go to Ansys results and calculate the surface temperature (average, maximum, and minimum) on the same wall, I got a very satisfied results and within the range of what I need to condensate the water vapor compared to the one calculated by the UDF.
is the UDF calculate the temperature of the water vapor at that wall and its shadow?
part of my UDF code (this part inside the adjust function):
mp_thread_loop_f(tf, mixture_domain, pt)
if (DOMAIN_ID(tf) == 2) /*ID for mixture of gas phase 1*/
begin_f_loop(f,tf)
tc = THREAD_T0(tf);
c = F_C0(f,tf);
pt = THREAD_SUB_THREADS(tc);
ti = pt[0];
cell_temp = C_T(c,ti); /*very high compared to the wall temperature wall */
wall_temp = F_T(f,tf); /*same very high*/
sajaalrifai is offline   Reply With Quote
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 12:04
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
