September 2, 2020, 22:10 |
Coupled fluid-fluid interface?
Carlos Álvarez
Hello, good day.
I'm doing my master degree about water desalination by solar stills with phase change materials in the bottom. Right now I'm trying to run the simulation without PCM and whole "interesting" part is that I'm not using any multiphase models or evaporation-condensation equations Fluent has (using only UDFs, but that's another topic). The thing is that when I run the simulation in order to get the mass fraction of water, I received an error message: "Species are not solved in neighbor cell threads" and ID of cells and boundary conditions referenced to this problem. I was reading an article that considered the water and the mixture vapor-air interface as a coupled wall, however I don't know how it will work as a wall or how to setup this in Fluent. For example I made the coupled wall for the glass and mixture interface but I don't know if it is possible to do this in a fluid-fluid interface. I'm attaching the geometry and the mesh: https://ibb.co/xFhc4Hc https://ibb.co/TcqwVBk And this is a snippet from the article I mentioned before: https://ibb.co/28XPbDm I believe there is something about the geometry or meshing setup. For the fluent, I activate the energy, species, radiation and turbulence models and indicate the cells for water, mixture and glass, and when I try to initialize the simulation I receive the error above with bold letters. I will appreciate your help. I don't know if I was clear enough. Last edited by rock_md; September 2, 2020 at 22:13. Reason: Images don't show. |
solid fluid coupled interface problem to find out 'h' value? | Rajaero | FLUENT | 2 | September 2, 2019 01:12 |
Fluid Domain moving with Rigid body | Lloyd Sullivan | CFX | 3 | August 17, 2018 10:58 |
My radial inflow turbine | Abo Anas | CFX | 27 | May 11, 2018 02:44 |
Low torque values on Screw Turbine | Shaun Waters | CFX | 34 | July 23, 2015 09:16 |
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source | silvan | CFX | 3 | June 16, 2014 10:49 |
