Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Time step size changes drag coefficient?
Old   August 27, 2020, 09:45
Default Time step size changes drag coefficient?
mmengineer is on a distinguished road
Hello everyone,
i´m simulating an Open-Channel problem and i´m trying to get Drag values of bridge inside that open channel. The simulations works and i´m getting results for the Drag coefficient. The global courant number of the problem is under 1 with a time step size of 0.005 s and the calculated drag-coefficient is about 0.9.
But when I change the time-step-size to 0.0025 s the drag-coefficient jumps up to about 1.1 and will stay there.
When i change the time-step-size to 0.00005 s the drag-coefficient jumps up to about 30.
When i look at the calculated drag forces the same thing will happen, so i guess it´s not a problem of reference values or something, but a problem inside the simulation. But i can´t figure out what causes the problem, since the courant number is below 1 in every of the simulations.
Can anyone help me with this problem or does anyone at least have an idea what causes this behaviour of the simulation.
Thank you very much
mmengineer is offline   Reply With Quote
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
[snappyHexMesh] crash sHM H25E OpenFOAM Meshing & Mesh Conversion 11 November 10, 2014 12:27
plot over time fferroni OpenFOAM Post-Processing 7 June 8, 2012 08:56
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
