Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Simulation for water jet spray using fluent multiphase
Old   August 16, 2020, 10:44
Default Simulation for water jet spray using fluent multiphase
Daidalos94 is on a distinguished road
Hi guys, am new here. I would like to conduct a series of simulation of high pressure water jets into air with a fan nozzle angled at various angles to look at the primary breakup (fan angle) as well as the flow trajectory. I plan to start with a 2D analysis. My inlet velocity is in the range of approximately 140 m/s and outlet is 0 gauge pressure with atmospheric operating pressure.
Currently I am looking at multiphase VOF model to capture the interface between water and air with surface tension modelling and turbulence modeled with standard k-epsilon. however, I am unable to capture the desired variations in jet spray angle. So my question is really what dictates the spray angle in the vof analysis so that I am able to capture different spray angles. I did some research and it seems to be heavily tied to the nozzle geometry. but under cicumstances that i can not model the exact nozzle geometry, are there any thermodynamic properties which leads to this variation in spray angle that i can utilise in fluent?
Also, I am using the student version so I am limited in the number of cells in my model. will it greatly affect the solution of the spray angle?
thank you in advance for any assistance.
Daidalos94 is offline   Reply With Quote
multiphase flow, spray atomization, vof method, vof multiphase, water jet
Spray Simulation in Fluent machineengine Fluent Multiphase 0 June 7, 2017 09:19
Thermal Simulation using Multiphase VOF model in Fluent hari.poudyal47@gmail.com Fluent Multiphase 0 July 20, 2015 12:31
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
Convergence of jet flow simulation MiraLisa FLUENT 0 August 15, 2013 05:44
LSR (Land speed record) car simulation on FLUENT Maxime31850 FLUENT 2 May 1, 2013 12:15
