Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
How to add this Expression
Old   July 26, 2020, 14:40
Post How to add this Expression
Raj
Rajkool is on a distinguished road
Hello all,
I am trying to add this pressure drop expression at Outlet in VOF model. But it is not accepting the units. I am just editing it in the Expression editor using the report definition. I do not want to compile using C code.
Please help me with writing expression.
Pressure Drop = C1(Report def/diameter^2)+C2
( I have given {report-def}*1[m/s], if I give m/s it is not accepting and if I add the diameter with [mm] as units. It is not acceting)
where c1 and c2 are constants, diameter can also be taken as constant because it does not change i.e., I can give the number directly.
Thank you
Raj
Rajkool is offline   Reply With Quote
Outlet boundary condition in interFoam Andrea_85 OpenFOAM Running, Solving & CFD 51 July 20, 2017 14:31
Error reading profile data in expression in cfx post banu CFX 4 March 27, 2015 10:03
Something doens't work with wallHeatFlux utility or externalWallHeatFluxTemperat BC!! zfaraday OpenFOAM Post-Processing 0 February 5, 2015 17:47
Lift, Drag Vs time chart,calculations Jamesd69climber CFX 8 February 17, 2005 18:23
Creating, loop or iteration using expression edito Jan CFX 3 July 28, 2003 12:01
