Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Problem related to multiphase flow with species transport equation
Old   July 23, 2020, 20:26
Default Problem related to multiphase flow with species transport equation
Anshuman Sinha
Anshs is on a distinguished road
I am modeling a multiphase flow with species transport equation. There are phases like a water column and overlying oil phase, and the water column is being stirred with DPM particles.
Both water and oil phases are defined as mixture material like water = h2o(liq) + hnco ( 0.001 fraction) , oil = diesel(liq) (0.99 fraction) + O2 (0.01 fraction).
I'm using the implicit VOF method for interface tracking, and the PISO algorithm for p-v coupling.
The results are not satisfactory when I'm using mixture materials for the phases.
Initial condition: There are 3 phases of water, oil, and air. each lying above the other in order of density ( water, oil, air).
Results ( when phases are not defined as a mixture ): These results are satisfactory with the experiments.
Results ( when phases are defined as a mixture ) :
These results when the material is defined as a mixture are not as expected. I'm also attaching the species plots and velocity profile plot:
Screenshot 2020-07-24 at 4.50.03 AM.jpg.
Thank you for all the help.
Anshs is offline   Reply With Quote
dpm, mixture., multi phase, species tranport, vof method
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 05:37
Species transport model problem argeus FLUENT 8 September 20, 2019 08:23
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Weird problem in FLUENT Species Transport Bin ANSYS 0 September 24, 2013 21:41
Multiphase flow problem icedou FLUENT 6 July 10, 2005 03:52
