Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Drag Force on a droplet
Old   July 22, 2020, 21:55
Default Drag Force on a droplet
Mohamed Wael
Mwbadawy is on a distinguished road
I am simulating the motion of a water droplet inside an oil medium using the VOF Multiphase Model. I want to calculate the drag force exerted on the droplet. My approach was to integrate the pressure and shear stress over the droplet surface (ISO surface) However, I couldn't calculate the shear stress on any non-wall cells.
I have found a parameter in CFD-Post variables called "water. Force X", Does this variable define the drag force directly, if not what does it mean and what might be a good way to calculate the drag force?
P.S. I can provide any images if needed.
Thanks
Mwbadawy is offline   Reply With Quote
Old   July 23, 2020, 16:22
Mohamed Wael
This is the expression I used to validate the drag force at the walls:
=areaInt(2*Velocity u.Gradient X*Normal X*0.1[N*sec/m^2]+(Velocity u.Gradient Y+Velocity v.Gradient X)*Normal Y*0.1[N*sec/m^2]+(Velocity u.Gradient Z+Velocity w.Gradient X)*Normal Z*0.1[N*sec/m^2])@walls
but it doesn't give the same results as the wall shear built-in parameter.
cfd - post, droplet microfluidics
Applying drag force in the fluid model CanadaFlanker CFX 7 May 6, 2014 00:13
Force vectors for drag during sweeping motion aamer FLUENT 0 April 18, 2011 09:17
exporting drag force from fluent fluentguy FLUENT 2 October 27, 2009 15:19
drag coefficient & drag force abhishek.mnit FLUENT 0 April 30, 2009 00:48
Airfoil Drag Force wowakai Main CFD Forum 3 October 13, 1998 20:27
